Activity Forums VEGAS Pro AVCHD to DVD – best project/rendering settings in Platinum 11?
  • AVCHD to DVD – best project/rendering settings in Platinum 11?
    Posted by Matt Moore on August 30, 2012 at 9:53 pm
    Hello, this is my first post, but I’ve already picked up loads of useful info from this site.
    I’m finally making the switch from SD (old Sony PDX10) to HD (Pana GH2, hacked). However, my output is entirely on DVDs for friends and family.
    I have a mixture of footage from the GH2, e.g. 1080i (25 fps), 720p (50 fps), and I want to put it all in the same project in order to burn a PAL DVD. The thing is, I’ve noticed that I always end up with some jaggies or other artifacts like that when I create an avi file from the raw footage and also when I create an mpeg2 file too.
    Does anyone have any idea what I need to do to avoid this? I’ve tried playing around with the interleave/blend settings, but it doesn’t seem to make any difference.
    Thanks in advance.
    Matt
    John Rofrano replied 14 years ago 2 Members · 3 Replies
  • John Rofrano
    September 1, 2012 at 1:18 pm
    [Matt Moore] ” I’ve noticed that I always end up with some jaggies or other artifacts like that when I create an avi file from the raw footage and also when I create an mpeg2 file too. Does anyone have any idea what I need to do to avoid this?”
    Make sure that you are using the Best setting when you render. The Good setting is the default, and is fine for rendering to the same size as your source but if you are resizing your video like you are, you should use Best to make the resize smoother.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matt Moore
    September 2, 2012 at 8:17 pm
    THANK YOU!
    So many options to check, but I managed to overlook that one!
    Matt
  • John Rofrano
    September 2, 2012 at 8:27 pm
    You’re welcome. There’s a lot to know. Glad that fixed it for you.
    ~jr
