Activity Forums VEGAS Pro AVCHD Render to MP4
  • AVCHD Render to MP4
    Posted by John Kendrick on January 21, 2013 at 1:32 pm
    I have been trying to render AVCHD footage to an MP4 file. It will render a chunk of frames (approximately two hundred), then wait for a few seconds, and then render frames again (another couple of hundered) and wait a couple of seconds, so on, and so on . . .
    It takes a good while, twenty plus minutes, to render the file.
    On my old machine it took only eight minutes, my new machine is taking twenty-five or there abouts.
    Any ideas on why it would do that “wait” and then progress again?
    I have read about it passing back to the codec to make sure its producing the file in the best way possible… fine – I get that, however, my old 8GB i7-950 doesnt have this issue and my new 16GB i7-3770s does…
    What am I missing??
    Vegas Pro 12 Windows 8 Pro is my new machine. Win 7 Pro Vegas Pro 12 is my old machine…
    John Kendrick replied 13 years, 8 months ago 3 Members · 4 Replies
  • Graham Bernard
    January 21, 2013 at 2:27 pm
    [John Kendrick] “What am I missing??”
    “HandBrake”?
    I’m having great success with it. Try it – you might ;like it. It is free and does the job – lickety split! – Mind you, I haven’t tried AVCHD, so try it and see.
    Handbrake : https://handbrake.fr/
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
  • John Kendrick
    January 21, 2013 at 5:57 pm
    Sorry – I wasnt intending to cause confusion.
    I have a vegas pro 12 clip all built and ready to go. Its made of lots of AVCHD clips with a few basic transitions.
    When I go to render in MP4 the issue that i have described above occurs. The same file on older hardware is much quicker – the new system is at least twice as slow, if not slight more.
  • Mike Thomas ii
    January 21, 2013 at 8:41 pm
    Hi John,
    This could be any number of causes, even Windows 8 itself or a driver issue. Mind you that I am running Vegas 11. And I do not know your system setup so…
    Check the render options under ‘Encode mode’ (default – Auto, Render CPU, Render GPU) and try forcing the ‘Render GPU’ option. But first, update the video drivers. Also try turning off any anti-virus programs.
  • John Kendrick
    January 22, 2013 at 12:45 pm
    I am going to create a new discussion about this area . . .
