Activity › Forums › Adobe Premiere Pro › AVCHD renames?
AVCHD renames?
Posted by Kent Beeson on June 18, 2015 at 4:26 amLatest PP CC 2015 how to import and rename 200 clips from the original AVCHD gibberish file name to custom file name I need?
THX
Paul Neumann replied 11 years, 2 months ago 3 Members · 6 Replies -
Trent Happel
June 18, 2015 at 5:14 amNot really any good way in Premiere other than renaming one by one in the Project panel. You could use the File Rename option in the Ingest panel of Prelude and then File menu > Send to Premiere Pro.
Trent Happel
Adobe
Premiere Pro -
Kent Beeson
June 18, 2015 at 5:16 amIs there a link or tutorial somewhere on how to do that in PRELUDE latest?
Trent Happel
June 18, 2015 at 5:24 amThese are existing docs and demos, but should still be applicable to CC 2015:
https://helpx.adobe.com/prelude/using/prelude-projects.html
https://helpx.adobe.com/premiere-pro/how-to/prepare-media-batch-process-prelude.htmlTrent Happel
Adobe
Premiere Pro -
Paul Neumann
June 18, 2015 at 4:08 pmPrelude CC 2015 doesn’t seem to be recognizing AVCHD file structure at the very top. You can drill down to the clips, but it’s not working like it used to where you pointed it to an AVCHD structure and it just showed you the clips.
Older file structures are working fine, but stuff I just shot yesterday is not being seen correctly.
The “View As” dropdown defaults to File Directory and all other options are greyed out.
Kent Beeson
June 18, 2015 at 4:53 pmSo, I’d simply then have to import all 200 clips individually, then tell provide to transfer and rename each clip? Can it do that automatically with avchd?
Paul Neumann
June 18, 2015 at 5:50 pmIt does it all at once. Ingest and rename. You don’t have to transfer and/or transcode if you don’t want to. No different than importing the 200 clips. You’re just having them renamed when you import them.
