Activity Forums Adobe Premiere Pro AVCHD problem
  • AVCHD problem
    Posted by David Gilhooly on February 19, 2009 at 11:17 am
    I have just started to use Prem pro CS4 as it supports my new HD Camcorder file format, AVCHD. I am having a bit of trouble getting the AVCHD files to play in PREM pro CS4, As the video starts fine for about the first 2 seconds then it stops. However the sound can still be heard.
    I am using a Dell XPS Gen 3 3.4Gh processor with 2gb of ram.
    I would be glad of any help.
    David
    Clint Milner replied 17 years, 7 months ago 3 Members · 3 Replies
  • Vincent Rosati
    February 20, 2009 at 9:50 pm
    Generally, playback issues are codec issues. Could be a corrupt file.
    Open the file with GSpot (pc) to determine if the video codec is one that is compatible with Premiere. It would also indicate if there is any damage to the file.
    Are you capturing with Premiere?
    Worst case scenario is that you would have to decompress all of your source prior to import.
    Vince
  • Clint Milner
    February 25, 2009 at 10:52 am
    Hi David,
    I’ve run across this as well. From what I hear, AVCHD is an HD format, but it’s still compressed and pretty resource intensive.
    I’m on XP Pro w/ 3GB RAM AMD Athon 64 x2 2.81GHz by the way.
    I talked to some experts at the Broadcast VideoExpo last week in London and some of them told me to bring the footage into Adobe Media Encoder and render it to MPEG2 and then take it into Premiere. I haven’t tried it, but it is worth a shot.
    I have the luxury of upgrading to a proper digital editing suite from scan.co.uk, but if upgrading isn’t in the cards, that may help.
    Cheers,
    Clint
  • Clint Milner
    February 26, 2009 at 2:11 pm
    Responding to my previous post:
    I have converted AVCHD to mpeg2 for blu-ray, and premiere runs much more smoothly.
    I’m currently waiting for a test disc to render to see the quality.
    Clint
