Activity Forums VEGAS Pro AVCHD MXP(24mbps)
  • AVCHD MXP(24mbps)
    Posted by Tiago Brito on September 23, 2009 at 11:36 am
    Hi. I have a Canon HG20 and i made my movies at MXP mode, 24mbps
    But when I trie to edit them in Vegas Pro 9 64bits using: .m2ts and template AVCHD 1920×1080-50i the video slowdown in some parts, because the max mbps is 16.. How do i render to .m2ts with 24mbps?
    I wish to edit so I can burn an AVCHD on DVD+R DL
    Regards.
    Tiago Brito replied 16 years, 11 months ago 2 Members · 3 Replies
  • Bob Peterson
    September 23, 2009 at 1:48 pm
    Editing speed and rendering speed are two different things. Your computer is not powerful enough to deliver 24fps. The render will deliver the frame rate that you select.
  • Tiago Brito
    September 23, 2009 at 1:57 pm
    yes it is powerfull enough.. Because I tried to do it with IMAGE MIXER 3 SE and it’s OK.
  • Tiago Brito
    September 23, 2009 at 1:58 pm
    I allready tried that. but the problem is that in vegas as .m2ts the max mbps is 16 and in .mp4 the max is 20..
