Activity › Forums › Adobe Premiere Pro › AVCHD media naming
  • AVCHD media naming
    Posted by Steve Brame on May 1, 2012 at 2:36 pm
    With the good news being reported about CS6’s greatly improved handling of AVCHD files, I’m hoping that we can finally skip the intermediate transcode to Cineform, saving a literal ton of drive space. However, there is one thing about the file and folder structure that most AVCHD cams use that causes a problem. Our HMC-150 creates media in folders named by date…
    021512_1
    021512_2
    021612_1
    043012_1
    And of course, in each folder the clip naming goes…
    00000.m2ts
    00001.m2ts
    00002.m2ts
    So, you load your media into Premiere, edit your program, and somewhere down the line you lose the media links, causing Premiere to start asking for files on project startup. Trouble is, Premiere will ask for the file named ‘00000.m2ts’ first, not specifying which ‘00000.m2ts’, and there will probably be several identically named files spread across the folders. Choose the wrong one, and it will be painfully evident that you did, because most of the other clips will now be linked to the wrong files.
    What we’ve typically done, when transcoding to Cineform, is rename the transcodes to include each file folder name…
    021512_1-00000.avi
    021512_2-00000.avi
    021612_1-00000.avi
    043012_1-00000.avi
    This takes care of the file name issue. However, I understand the ramifications of renaming the actual M2TS files, especially in the instance of spanned clips. Is there a common way that folks are handling this?
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Chris Borjis replied 14 years, 5 months ago 3 Members · 4 Replies
  • Chris Borjis
    May 1, 2012 at 4:15 pm
    my workaround has been to make sure the recording on the media
    never resets to zero. We keep the original recordings on the sd cards when
    shooting more footage….but I understand that won’t work in all situations.
    So far what I’ve been doing is importing footage into separate folders
    and keeping notes as to what goes in where.
    another option is to make a copy of your media (should be doing this anyways
    as a virtual tape master) and rename the files before you import them.
    /camera_files/ = original unaltered camera media
    /footage/ = copy camera files, but renamed files to import
    Not the best option, but it works for now.
  • Robert Brown
    May 2, 2012 at 6:26 am
    I just installed CS 6 today. Sorry to report MTS files would not play back at all on a 12 core Mac Pro. Played OK in CS 5.5 although not great. So much for that.
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
  • Steve Brame
    May 2, 2012 at 1:03 pm
    Deep breaths……
    Steve Brame
  • Chris Borjis
    May 2, 2012 at 6:56 pm
    [Robert Brown] “I just installed CS 6 today. Sorry to report MTS files would not play back at all on a 12 core Mac Pro. Played OK in CS 5.5 although not great. So much for that.”
    I’ve been playing .MTS files just fine on an 8-core mac pro
    with quadro 4000 and Raid 5 disk array through a very old
    multibridge extreme from Black Magic.
    with cs 5.5 stacked video tracks always stop or stutter without
    finishing, even when fully rendered some times.
    in CS 6 that stopping/stuttering is completely gone.
