Activity › Forums › Apple Final Cut Pro Legacy › AVCHD .M2TS Clipwrap
  • AVCHD .M2TS Clipwrap
    Posted by Lisa Koza on February 25, 2012 at 1:19 am
    Hi, I have FCP 7, editing on a macbook pro 2.4 GHz Intel Core 2 Duo, 4 gig mem, Snow Leopard 10.6.8, and 4 hours of footage in AVCHD m2ts. I bought Clipwrap, have the latest one. My edit is in HDV, and I’ve been trying to output from Clipwrap in HDV….but it’s taking forever!
    I’m here wondering if there’s a faster way, or is that just how it goes? I left 1.31 hours of footage working over night, and it wasn’t done when I woke up. Sounds wrong to me. Any hints, tips and other offers?
    Oh, also, I tried just wrapping it, but it won’t play in FCP. Audio comes out in time, but footage just jumps sloooow.
    Lisa
    Ionescu Georgian replied 13 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    February 25, 2012 at 1:21 am
    Don’t convert to HDV…convert to ProRes. Edit in a ProRes sequence. If you are mixing with HDV footage, HDV in a ProRes sequence will be just fine. Better than in an HDV sequence actually.
    Shane
    Little Frog Post
  • Lisa Koza
    February 25, 2012 at 1:32 am
    Hi Shane,
    Yes, I am editing in HDV. It was a 4 camera shoot at a concert, 2 cams HDV codecs, and then two other Sony’s in AVCHD. I just tried a small sample in ProRes HQ from Clipwrap and it’s jumpy still, and, I get that red render line in my HDV Sequence when adding the ProRes, as well as a ProRes Sequence, with HDV….red lining. I prefer to convert to HDV, but I guess you’re saying that’s why it’s taking me so long….because I’m going out to HDV? Ugh, thought this would be simpler. 🙂
  • Lisa Koza
    February 25, 2012 at 1:56 am
    46 Second AVCHD clip took 8 mins ProRes HQ output from Clipwrap. Same clip HDV output took 13 mins. HDV plays fine though in FCP, not jumpy. I guess I just have to endure the wait?
  • Steve Eisen
    February 25, 2012 at 2:11 am
    [Lisa Koza] “I just tried a small sample in ProRes HQ from Clipwrap and it’s jumpy still”
    ProRes HQ is overkill for your MBP and will slow it to a crawl. Use ProRes or ProRes LT.
    Fast hard drives (RAID) also make a difference in playback performance.
    I would suggest convert everything to ProRes. HDV is very taxiing on your MBP especially using multicam.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    February 25, 2012 at 3:26 am
    Two other cams are HDV, and you need to master to HDV. Well, seems like there’s only one choice then…
    Shane
    Little Frog Post
  • Lisa Koza
    February 27, 2012 at 8:59 pm
    Thank you both for your input. I couldn’t stand the super long conversion to HDV in clipwrap, so I did go with ProRes LT. It still took 5 hours for an hour and half of footage, but it was better than 24!
    Now I need to re-digitize my other tapes and just edit in ProRes. Hopefully I’ll be able to deliver in that as well. thanks 🙂
    Lisa
  • Ionescu Georgian
    October 29, 2012 at 12:12 am
    I went with ProRes LT the moment I found out what this .m2ts file extension was all about.
    I suggest you always search for what a .m2ts does before you try to do anything with it and then get the appropriate program for your cam. I got my documentation from https://www.dotwhat.net and also the recommended ProRes LT for my cam.
