Activity Forums Apple Final Cut Pro Legacy AVCHD Log and transfer trouble.
  • AVCHD Log and transfer trouble.
    Posted by Christopher Targia on May 31, 2012 at 7:44 pm
    I received some files from a memory card that was sent to me, they orginally just sent me the .MTS files but after I explained to them I needed the whole card for Final Cut Pro to read them, they sent me what appears to be the whole card.
    However, when I try to log and transfer I still have trouble
    What’s going on here? Did they miss a folder or something? what is the file structure supposed to look like?
    MacPro Octo Core Intel Xenon 2.8Ghz 10GB DDR2 Ram
    FCP 7.0.3
    -I highly recommend el Gato Turbo264HD-
    Phillip Todd replied 14 years, 3 months ago 3 Members · 4 Replies
  • Everest Mokaeff
    May 31, 2012 at 7:57 pm
    Do not select Card or STREAM folder. Instead select the BDMV folder for it’s root folder from CF.
    Production and Postproduction in Moscow
    http://www.mokaeff.com
  • Christopher Targia
    June 1, 2012 at 12:54 pm
    I tried this also and had the same result
    FCP 7.0.3
    June 1, 2012 at 1:06 pm
    it is a Panasonic HC-V700 full HD camera
    FCP 7.0.3
  • Phillip Todd
    June 2, 2012 at 6:04 pm
    I had this once with a card that was corrupted. Had to rewrap the files using ClipWrap (v2.4.6 I think) into ProRes, then import into FCP 7.0.3
    Phillip Todd
    Cinematographer
    Philadelphia – NYC – Zurich
    https://vimeo.com/philliptodd
