Activity Forums Apple Final Cut Pro Legacy AVCHD Log and Transfer Problem
  • AVCHD Log and Transfer Problem
    Posted by Sean Oneil on January 13, 2009 at 9:53 pm
    Got a stack of mini DVD-R discs from a client. Don’t know what camcorder was used but it’s AVCHD.
    Log and Transfer sees it fine and I can play it in the preview player, which looks perfect. But when I import it to either ProRes or AIC, the resulting file is messed up. Hard to describe, I guess it’s skipping frames.
    There’s an option to “remove pulldown and duplicate frames.” Same problem with and without that option (it’s 60i so I don’t need it anyways).
    Sean Oneil replied 17 years, 7 months ago 1 Member · 1 Reply
  • Sean Oneil
    January 13, 2009 at 10:20 pm
    Had to uninstall “Perian” and remove the components from the /Library/Quicktime. That fixed it.
    Sean
