Activity › Forums › Adobe After Effects › AVCHD in AE CS3
AVCHD in AE CS3
Posted by Da Sh on November 8, 2007 at 9:45 pmGreetings, I’ve bought a SONY HDR SR5 which records in AVCHD format. (The native format of SR5)
I want to edit my videos in AE CS3 but it can’t import those files. The only solution I found is to convert it but it causes loss of quality. I’ve heard that Sony Vegas supports AVCHD but I need to work on AE CS3. Does anyone have a solution?
Paul Ezzy replied 15 years, 9 months ago 4 Members · 6 Replies -
Steve Roberts
November 8, 2007 at 10:02 pmAE doesn’t like importing files compressed with MPEG-type codecs. You need to convert it to something that uses all I-frames, such as Photo-JPEG at 89%+ or Animation.
It’s an acquisition codec, not an editing codec, and certainly not a compositing codec. It might even be a “consumer” codec, with very limited editing support.
If you Google AVCHD, you should find some options, Vegas being one of them. Premiere’s support is not clear.
Da Sh
November 11, 2007 at 8:23 pmI own Vegas but I really want to do editing in CS3. So you think that I should first convert it in order to import it in AE. Ok.
But is there a software that you would recommend?
I’m not familiar with converting software. -
Steve Roberts
November 11, 2007 at 8:52 pmYou need to find an application that will open AVCHD files. That is your limitation.
Try Vegas or Quicktime Pro.
That camera is not a professional camera, and the codec is not a professional codec for editing, effects or compositing. Expect some difficulties in post like this.
Evideom
November 29, 2007 at 1:37 amShould I get a miniDV HD consumer cam or a AVCHD consumer cam?
I like messing around with AE and NLE, what would be the better choice? -
Steve Roberts
November 29, 2007 at 3:33 pmBuying an AVCHD camcorder is just asking for trouble. Read the earlier posts.
Paul Ezzy
December 27, 2010 at 2:40 amI’ve had some luck using MainConcept’s MPEG Pro HD, but it was inconsistent. At first, it let me view (and edit) footage in AE CS3 and PPro CS3, and I know this because I’ve exported such clips.
However, after some time it stopped working in AE (didn’t keep trying in Premiere). I wasn’t sure why, and when I asked their tech support they said AE was not officially supported for the process I was using.
Nevertheless, it’s worth a trial run.
https://www.mainconcept.com/en/products/apps-plug-ins/plug-ins-for-adobe/mpeg-pro-hd-cs-4.html
Hope it helps. I’m currently looking for a permenant solution to this problem myself (that doesn’t involve getting CS5) 🙂
-Paul E.
