Activity Forums Adobe Premiere Pro AVCHD Import/Sync Issue
  • AVCHD Import/Sync Issue
    Posted by James Barry on May 16, 2019 at 6:22 pm
    Posted this over at Adobe and figured I’d post it here too, to up the chances of getting a solution for this:
    I’ll try to keep this as short as possible with as much info is needed. This is the order of events to give you a clear picture…
    – A drive with footage (AVCHD) was handed off to a freelancer
    – The footage was sync’d with Pluraleyes and exported as XML
    – The XML was imported into Premiere
    – Project file was edited and the project file (PRPROJ) was sent back for finishing in house
    – When the project is opened in house with the same footage on our server, all clips are striped out with incorrect in-out points.
    Notes:
    – Shot on Canon C100 mkii
    – Both sides are running CC2018 (versioning doens’t matter, I’ve encountered this issues in nearly every build of Premiere)
    – The project was shot in different frame rates, some 24p, some 30p, some 60p
    Things I’ve tried:
    – Renaming the folder structure within the AVCD and re-connecting media when it was recognized as “missing”
    – Pulling the STREAM folder out of the AVCHD and re-connecting media that way
    – Exporting as XML and importing XML into a new project
    Is there any way to resolve this indexing issue? I appreciate any hint’s, tricks, work-arounds, or solutions anyone might have. Thanks.
    James Barry replied 7 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
