Activity › Forums › Apple Final Cut Pro › AVCHD from hard drive or FCPX archive
Jane Kong replied 11 years, 9 months ago 5 Members · 16 Replies
Morten Slemdal
November 19, 2014 at 7:11 pmEasiest way is probably just import it directly from camera to fcpx, and then do my backups – just had a plan to store the “originals”
Morten Slemdal
November 19, 2014 at 7:15 pmOk, if I take then out of the private, it works. From the import manager Fcpx just don’t read the avchd folder – it does’nt show up – and it’s not saved at the root structure
Morten Slemdal
November 19, 2014 at 7:51 pmJust have to drag and drop the mts files from Finder to fcpx.Inside the avchd is the bdmv, and this just make fcpx confused, I guess. Did’nt work to take the mts out.
Claude Lyneis
November 20, 2014 at 5:39 amI back up AVCHD from cards after a shoot by just making a folder, naming it to identify the contents and then drag the whole AVCHD file into it. FCPX can open it just as it would from the card because the whole structure is preserved. I use FCPX to read the card and make my primary copy for editing. When I finsh, I have 2 independent copies, in case something goes wrong with one of them.
Jane Kong
December 2, 2014 at 7:12 amNot sure if your problem has been solved or not, but still want to post my ideals. Did you copy the entire structure of your video folder? If this videos are “Orphan” avchd files, then it must be a little bit difficult to import them into your fcp. what camera you used? like Canon, Sony , they all have their own plug-in gear to help customers to import their videos into edit software.
