Activity Forums Adobe Premiere Pro AVCHD from C100MII aliasing Premiere vis Prelude
  • AVCHD from C100MII aliasing Premiere vis Prelude
    Posted by Mark Dagostino on March 4, 2015 at 4:37 pm
    I am shooting AVCHD 24mbps/PsF29.97. When I ingest .mts files into Premiere via Prelude without transcoding the aliasing is not bad but still unacceptable. If I transcode to ProRes422HQ via Prelude the aliasing is horrible in Premiere. Using modify/interpret footage does nothing and the sequence is set to progressive. We prefer using Prelude for its far more efficient renaming/logging/metadata process over simply coming in through media browser because several producers share a massive server with all our footage.
    Am I expecting too much from the C100 in AVCHD? We also have a Ninja2 but occasionally for run and gun we’ll need to keep it simple and run with the sd card.
    8623_avchdaliasingtestc100mii.mp4.zip
    Mark D’Agostino
    Video Producer
    Creative Media Productions – Exelon
    Baltimore, MD
    MacPro,2.7 Ghz 12-Core Intel Xeon E5, 64GB 1866 Mhz DDR3 ECC, AMD FirePro D700 6144MB
    Mark Dagostino replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
