Activity › Forums › Apple Final Cut Pro Legacy › AVCHD footage, FCP 6, 1080 30p
  • AVCHD footage, FCP 6, 1080 30p
    Posted by Kelly Cicero on June 6, 2009 at 9:43 pm
    A couple problems with my my work flow.
    I have ingested 1080 30p footage from a Panasonic HMC150 into my “Better” model iMac. When I pull it into FCP6 (just bought it this month) with “Log and Transfer” then attempt to playback two things occur.
    1) All footage needs to be rendered on the timeline for playback (just to view it)
    2) The aspect ratio seems off. Very long footage (looks to be 2560 x 1080).
    Can anyone tell me what I am doing wrong?
    Thanks in advance…and sorry if it is an obvious answer.
    Specs…
    24-inch model iMac
    2.93GHz Intel Core 2 Duo processor
    640GB 7200-rpm Serial ATA hard drive
    4GB (two 2GB SO-DIMMs) of 1066MHz DDR3 SDRAM
    NVIDIA GeForce GT 130 graphics processor with 512MB of GDDR3 memory
    1 TB external Lacie Drive
    I have been using QuickTime Conversion to create 1920×1080 HD files which takes forever, although it can then be imported and put on timeline with no rendering necessary to view. Help!
    Thanks again,
    Kelly
    Paul Figgiani replied 17 years, 3 months ago 4 Members · 4 Replies
  • Tom Wolsky
    June 6, 2009 at 10:52 pm
    What format did you shoot? What settings did you have set when you ingested your media? What are the item properties of your sequence?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Kelly Cicero
    June 6, 2009 at 11:48 pm
    Hi Tom:
    I shot AVCHD in 1080/30p. Settings for the sequence are HD (1280×1080) for aspect ratio, pixel aspect ratio HD (1280×1080) with field dominance “upper (odd). Quicktime video settings are compressor – “apple Prores 4229HQ). Rendering in 8-bit YUV.
    I didn’t see a project choice for the AVCHD format…chose the closest one that I could understand.
    Thanks for your help! I didn’t know how to find the “Log and Transfer” settings. Stealth mode placement?
    K
    Kelly Cicero
    Studio 17 Video
    http://www.studio17video.com
  • Steve Eisen
    June 7, 2009 at 1:38 am
    Read this tutorial:
    https://www.eventdv.net/Articles/Editorial/Tutorials/Cut-Lines-Using-the-AVCHD-Format-in-Final-Cut-Pro-52450.htm
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Paul Figgiani
    June 7, 2009 at 2:05 am
    Kelly,
    It looks like your sequence settings are off. The HMC 150 shoots 1920×1080 (or 1280×720).
    Depending on your Log and Transfer settings your clips will be transcoded to to ProRes (or to the Apple Intermediate Codec).
    Sequence settings:
    -paul.
