  • Posted by Peter Spenceley on December 26, 2010 at 6:29 pm
    I am ingesting AVCHD files from 2 different cameras, into FCP via Log and Transfer (using ProRes 433 (Proxy). The files from one camera, a Sony NX CAM appear to have a normal time code as one would expect. ie. what looks like original camera time code.
    However, files from the other camera , a Panasonic HS700 produce clips which all start at zero time code.
    Does the Panasonic HS 700 actually produce a zero timecode for each clip, or is FCP changing the time code as it ingests?
    many thanks if anybody has the answer.
    Peter
    Peter Spenceley replied 15 years, 8 months ago 4 Members · 6 Replies
  • Shane Ross
    December 26, 2010 at 7:56 pm
    The Panasonic is starting each clip at 00:00:00:00. The other AVCHD cameras they offer do the same thing.
    Shane
  • Chris Tompkins
    Almost all consumer level and most pro-sumer level cams will not have true time-code. Each take or session will start over with the pseudo time-code.
    The TC will not change after you ingest.
    Chris Tompkins
    Video Atlanta LLC
  • Peter Spenceley
    December 26, 2010 at 8:00 pm
    Many thanks for that information. A weight off my mind.
    Peter
  • Peter Spenceley
    December 26, 2010 at 8:01 pm
    Thank you
    Peter
  • Naiche Lujan
    December 28, 2010 at 4:56 pm
    Hey Peter,
    How is that workflow working for you? Once transcoding to ProRes are you running into any other problems?
    I’m curious because we’re looking to start shooting with a Sony NEX-VG10 that encodes in AVCHD.
    Cheers
    Naiche
    Mac Pro
    Dual 2.8Ghz Quad-Core
    16GB RAM
    ATI Radeon 256MB
    320GB 7200rpm
    3TB 7200rpm Internal Software RAID0
    Blackmagic Studio Card (working good so far)
  • Peter Spenceley
    January 7, 2011 at 1:05 pm
    Sorry it was a long time to reply, but I am now editing the project in ProRes (Prox) on FCP. Its fine at the moment but I am worried that this problem of clips all resetting time code to zero will become a disaster at the online process. I’ve already noticed that the FCP timeline indicates duplicate frames when there aren’t any.
    peter
