Activity › Forums › Apple Final Cut Pro Legacy › AVCHD Exporting
  • AVCHD Exporting
    Posted by Kathy Obrien on September 10, 2008 at 6:36 pm
    Hello all-
    I am working on a project which has regular DV input as well as one AVCHD shot that is a good portion of my project (we’ll call it camera 1). I am concerned, due to the size of the inital file, that when I export, using the typical Quicktime export with current settings, that the file will be way too large for a DVD. Do I need to convert the final project using compressor? Anytime I try to do this, I run into major issues. The last time I tried to get this project on a DVD, I tried for a week and was never successful – any suggestions?
    Kathy Obrien replied 18 years ago 1 Member · 1 Reply
  • Kathy Obrien
    September 10, 2008 at 8:02 pm
    There are 3 portions – 1 main video (40 minutes) and 2 extras (45 minutes and 15 minutes). I think all together it should be less than 2 hours.
    I will try compressor, but I get all confused once I get int there – there are so many options! And then I’ve also had problems with horizontal lines when I use compressor….
