Activity Forums VEGAS Pro AVCHD encoded MP4’s
  • AVCHD encoded MP4’s
    Posted by Darrin Salt on January 25, 2009 at 4:45 pm
    Hi All,
    I’ve been using Vegas Pro for some time (V6 to 7 to 8) but recently I’ve had a need to do some HD work. Didn’t think it would be too much of a problem with a dual core machine, 4gb RAM, fast drives and Vegas Pro 8. How wrong I was. Trying to edit AVCHD “full HD” (1920x1080p) is just a pig, it’s obvious I’m going to need an intermediate codec. Didn’t think that would be a problem, there are lots around.
    However, here’s the rub. The AVCHD files I have are .MP4 files and NOT MTS files (prior to this, I thought AVC files were pretty standard – ha !). They are encoded correctly as AVCHD’s, but the codec and the container (MP4, AVI, MTS etc) of course are not one-and-the-same.
    This is where I really start to run into problems. I can do very small “intermediate” conversions inside Vegas by dropping individual MP4’s directly on the timeline, rendering them out and then using the rendered version in a project. This is impractical when you have hundreds of very small MP4s. If I try and drop an hours worth of HD MP4’s (about 300 camcorder clip files) onto the timeline, Vegas processes about 30% of them onto the timeline before marking the rest as “Media Offline” (they are not) and then unceremoniously crashing.
    Doing research has led me try several things. I want these files converted to an intermediate format. Not a problem ? There are lots of applications to produce intermediate source files from AVCHD video. Yes there are, BUT ONLY FROM MTS, not from MP4 encoded AVC. I’ve tried Cineform Neo, NewBlue VASST AVCHD Upshift, ELECard Convertor Studio – you name it. None of them will read MP4 as the source. There are HUNDREDS of applications out there which will render to MP4, but not from it. I’ve found some cheap-n-nasty stuff (“Clone2Go video converter”) which will give me a pretty good SD copy of my MP4, but nothing which will do a HD conversion. I can use apps like Nero to do one file at a time, but I really need bulk folder-at-a-time intermediate conversion,
    I’ve pretty much exhausted the forums, Google etc. Hopefully someone here will have the answer, even if it’s “you idiot, the answer is under you nose here; http…”.
    Regards
    Darrin.
    Shane Etter replied 16 years, 9 months ago 7 Members · 20 Replies
  • 20 Replies
  • John Rofrano
    January 26, 2009 at 2:47 am
    Where did you get these files? If from a camera, what camera stores AVCHD files as MP4? Are you sure it’s an AVCHD camera and not just an MPEG-4 AVC/H.264 camera which doesn’t necessarily make it AVCHD. I’ve only seen MTS and M2TS used as valid AVCHD extensions.
    If Vegas can convert these files one at a time then you could use VASST Ultimate S Pro to set up a batch render to convert hundreds of these files at a time. It will load each one and render it to whatever format you need.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Darrin Salt
    January 26, 2009 at 1:05 pm
    Thanks for the information. Forgive my hd-newbie error – I was told it was a HD camera which produced AVC encoded files. It’s clear now that an AVCHD camera (producing MTS files) is not the same as an HD Camera producing video files (in my case, I’ve been given MP4 files) which are AVC. Confused ? I was.
    I’ll have a play with VASST software and let you know how I get on. This is a low budget production, a charity has given me the MP4 files which came from a Samsung HMX20C “Full HD” camera. Obviously consumer but nevertheless I wasn’t expecting to have to recode the files one-by-one (almost “by hand”). Yuk.
    Regards,
    Darrin Salt
    London, UK.
  • Darrin Salt
    January 26, 2009 at 9:44 pm
    Just an update.
    The VASST plug-in for Vegas does do the batch conversion, so I’m 90% of the way there – but Ultimate S Pro is such a sledgehammer to crack this nut. VASST’s upshift software would be much more appropriate – if only it read AVC’s which were MP4 encoded.
    I’ve never encountered such compatability issues before when it comes to conversion – is this just because HD / AVC is fairly new ?
    I spoke to the purchaser of the camera and they showed me articles which they read when choosing it which showed MTS as a poorly supported format and they assumed MP4 (supported by Apple et al) as an obvious choice. All I can say is MP4 might be OK for playback on dedicated hardware, but somethings got to give on the editing front.
    Back to my original message, I could really do with a simple, cost effective batch convertor for HD (AVC) encoded MP4’s. Does anyone know of such a thing ?
    Darrin Salt
    London, UK.
  • John Rofrano
    January 26, 2009 at 10:38 pm
    I’m not sure if it’s the newness or the unwillingness to support a standard. AVCHD is the standard and consumers should look for a standard solution but it’s tough when the AVCHD camera costs $500 and the MPEG4 camera costs $99.
    Well it certainly isn’t poorer that an unsupported MP4 format. 😉 They may have misinterpreted what they read. Even a poorly supported standard is still a standard and still has a better chance of interoperability than rolling your own MP4 file that no one supports.
    Unless you are using a Mac, it doesn’t matter what Apple does or doesn’t support (Besides, I thought Apple didn’t like anything that wasn’t a MOV file). MP4 has several profiles and not all software and cameras support all profiles so it causes a lot of problems.
    Have you tried VASST GearShift? It will happily convert all of your MP4 files to Sony YUV or CineForm AVI which edits beautifully in Vegas. This is a specialized version of what is in Ultimate S Pro (and costs a lot less) 😉
    ~jr
  • Allen Zagel
    February 10, 2009 at 9:01 pm
    Well, I got this Sanyo Xacti HD which is a full HD/AVCHD cam and will shoot at 1920 x 1080. Nowever like you the files are MP4 and not M2T’s. However I’m using it at 720p 30
    My Final Cut Express Log-and-Transfer won’t recognize them either.
    So I found this MPEG Streamclip, a free open source program and on my Mac Book Pro I convert them using AIC but for Windows (yes there’s also a wnidows version) I used Apple Motion JPEG and imported the files right into Vegas. No problems at all. Did my thing in Vegas then made a DVD in DVDA.
    But now I also have a lot of files to do so will look into Upshift as Streamclip won’t batch convert.
    Allen
    ASX Media Group, Inc.
    http://www.asxvideo.com
    NEW DVD – Europe, Trains-n-Trams
  • Adam Rose esq.
    February 10, 2009 at 10:54 pm
    have same situ of MP4 inside .AVI, from a helmet cam recording to SD card, and converted them last time using Super IIRC. Just picked more footage from client this weekend, and have to dig up previous workflow. I definitely didn’t use anything expensive last time.
    btw, the clips play best inside DivX player – haven’t tried the DivX converter since haven’t got the Pro version, but it’s also a possibility…….
  • John Rofrano
    February 11, 2009 at 12:01 am
    Actually the Sanyo Xacti HD not AVCHD at all and nowhere on the Sanyo site does it make any claims of being AVCHD. The files are just a non-standard form of MPEG-4.
    AVCHD UpShift won’t work because it only works with AVCHD compliant files. You can use Super(c) to batch convert a bunch of MP4 files to pretty much any codec that you have installed on your PC.
    ~jr
  • Allen Zagel
    February 11, 2009 at 4:25 am
    Hi John
    Wow! Okay my mistake. This is my first foray into any kind of HD. It says Full HD MPEG-4 AVC/H.264 It was easy for me to see and assume AVCHD seeing the AVC!
    So what does this mean then and how to edit and make a SD DVD?
    Do I still have to down convert or just lay it on Vegas timeline and edit? Now I’m stumped. Ive been using MPEG Streamclip and it seems to be working fine but maybe that’s not the way to go?
    thanks for the correction.
    Allen
  • Darrin Salt
    February 11, 2009 at 3:38 pm
    Hi all.
    Well I’ve solved my problem. I did try the Vasst products and although I had some success, it was a bit hit-and-miss (mostly due to the files and Vegas, not due to the Vasst products).
    However, I then came across a (free/open source) package called MP4Cam2AVI. Note this is not the same as the shareware MP42AVI product. What this essentially does is convert the MP4 file into an AVI file. It does not re-compress the contents, these stay as AVC. Because no recompression takes place, it’s very quick. It also offers the option of converting many to one, so if you’ve a lot of incredibley small MP4 files from the same event (typically most of these camera’s create a new file every time the record button is pressed), it can create a composite AVI. This makes your NLE behave the way it would have if you’d be using a tape as your source material, with just one AVI per “tape” aka memory card. It appears to be only a PC product, but if you’re a Mac user with Parallels, you won’t be phased by that.
    This isn’t the final part of the puzzle though, as Vegas won’t read the AVC encoded AVI’s (Sound only, video stream unsupported). However, lots of other converters now will and I selected Elecards AVCHD convertor. I did try Upshift, but that would not read the files. Elecard will read and convert, the major plus for me is that unlike many cheap convertors, it will output full HD .ts files from the input AVI’s. It also isn’t integrated into Vegas, which is a plus as I can run the conversions on another machine (It converts faster than I can edit, so that’s a bonus !).
    To summarise, I take my MP4 AVC/AAC files, pre-convert them to AVI’s with MP4Cam2AVI and then finally convert with Elecard AVCHD convertor. The two stage process is a bit of a problem but the first is very quick and I get MPEG2 .ts files which work perfectly in Vegas. Just drop them straight to the timeline/trimmer.
    Hopefully some of the HD convertor software writers will start handling MP4’s natively soon, especially because their is great confusion between AVC encoded HD and AVCHD !
    Darrin Salt
    London, UK.
  • Allen Zagel
    February 11, 2009 at 5:21 pm
    Hi Darrin
    I don’t think you really need to go through a 2-step process.
    Try out MPEG Streamclip
    https://www.squared5.com/svideo/mpeg-streamclip-win.html
    It will also convert to AVI among others. I convert to MOV files which Vegas has no problem editing.
    I did find out Streamclip (also open source & free) does do batch converting as well.
    Allen
