Activity Forums Adobe Premiere Pro AVCHD Editing
  • AVCHD Editing
    Posted by Perry Cheng on June 27, 2012 at 11:33 am
    All,
    I have been editing with CS5.03 for a while, but previously editing on M2t files. Nowadays, I edit mostly with AVCHD files. I realized either my computer is not able to handle that or my GPU is not good. Here are my specs, what others use to edit AVCHD footage in order to be smooth. Anytime I added a transition, it turn into slow motion in preview. Thanks.
    Intel Q6600 @ 2.4GHz Overclocked to 3.24GHz
    8GB RAM, Windows 7, Lots of HDD
    GTX 240 (96Cuda core) – tweaked so that CS5 sees it for Hardware acceleration.
    Sincerely,
    Perry
    Perry Cheng replied 14 years, 2 months ago 4 Members · 5 Replies
  • Jeff Pulera
    June 27, 2012 at 1:26 pm
    Hi Perry,
    Your processor is 5 years old, that is definitely the problem. Consider a Core i7 upgrade
    Jeff Pulera
    Safe Harbor
  • Petros Kolyvas
    June 27, 2012 at 1:55 pm
    I think it’s important to familiarize one’s self with what CUDA does (CS5): https://blogs.adobe.com/premiereprotraining/2011/02/cuda-mercury-playback-engine-and-adobe-premiere-pro.html
    and here (CS5.5/CS6) if you came here looking for similar info: https://blogs.adobe.com/premiereprotraining/2011/04/adobe-premiere-pro-cs5-5-improvements-in-cuda-processing-and-the-mercury-playback-engine.html
    Here’s an imporant section (this should be a PrPro sticky because it’s so misunderstood.
    Here’s a list of things that Premiere Pro CS5 and later can process with CUDA:
    some effects (complete list at the bottom of this post)
    scaling (details here)
    deinterlacing
    blending modes
    color space conversions
    While this list grew with CS5.5 and CS6, it doesn’t include pure encode/decode operations (yet.) That means AVCHD playback (and encoding in render), the part where video is decompressed (or compressed), is done in CPU (which needs to be upgraded as Jeff noted) before being handed off to the GPU for any acceleratable (is that a word?) effects.
    Part of the whole “native workflow” means we’ve shifted the tasks from being predominantly disk-intensive with Uncompressed, ProRes and DNxHD media to being processor intensive with compressed MPEG-2 and MPEG-4 formats.
    When these formats are packing average data-rates that are less than HDV, then there are a lot of calculations that need to occur behind the scenes to render those predicted frames (P), especially when they’re sitting next to bidirectional ones(B)!
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Mitch Drummond
    June 28, 2012 at 9:07 am
    Hi Perry,
    I edit most of my stuff in AVCHD as it is the format thay my NX5P spits out. 1080p 50I (PAL) files with Premiere Pro CS6.
    Work flow is great and very smooth. Have to agree you would need to update your CPU possibly even your old GTX to a newer one with more RAM as well to get any improved system Performance.
    I am running
    Intel Xeon W3550 @ 2.8hgz
    Windows 7 professional
    12gb Ram
    GTX570HD
    System works great and is very stable.
    Cheers
    Mitch Drummond
    Adobe Master Collection CS6
    GeForce GTX570 SC
    Windows Pro 7
    Intel Xeon W3550 @ 2.8ghz / 12 gig Ram
  • Perry Cheng
    June 28, 2012 at 9:53 pm
    thank you all… it is time to upgrade.
  • Perry Cheng
    June 29, 2012 at 12:04 am
    do you recommend i3, i5 & i7?
    Perry
