Activity Forums Adobe Media Encoder AVCHD DVD Template for Adobe Media Encoder
  • AVCHD DVD Template for Adobe Media Encoder
    Posted by Phil Green on May 17, 2015 at 2:36 pm
    Hi Folks
    Just wondering if anyone has a good AVCHD for DVD Template that they can share with me? I am using the current version of Adobe Premiere Pro, Media Encoder and wish to Encode footage as HD to Fit onto DVD.
    What I am after is a good general purpost template that I can use as a all for one file that is good for 1st AVCHD onto DVD and also for general PC and most Mobile Playback as well as Youtube. I know that it is a case of just tweaking out one of the MP4 Templates but am unsure of the settings, Profiles, etc. I understand the Max Safe Bitrate is 18mbs for HD going onto DVD-R Disc but is that total including the Audio or is that plus Audio at whatever it should be?
    I often do short videos 5-15 Minutes at a time so as said, if I can get a good work flow for making AVCHD Discs using Encore then It would be a good way to output the Original HD files to disc.
    I know that Premiere Elements does AVCHD From the timeline to DVD and I was also considering purchasing it for these jobs, but since the projects are already made in Premiere Pro CC 8.2 then I guess I am already on the better Software System.
    Anyway, as said if anyone can point me in the know or post links to some templates I can download, then that would be much appreciated, along with any other info on workflow Premiere Pro > Adobe Media Encoder> Encore CS 6. Last note, the footage I am mostly dealing with original files that is on the Premiere Pro Timeline is HDV PAL 50i and some 1920×1080 30p MP4 material
    Phil Green replied 11 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
