Activity Forums Apple Final Cut Pro Legacy AVCHD disc burn in FCP7
  • AVCHD disc burn in FCP7
    Posted by Reinhard Lorenz on June 8, 2010 at 5:44 pm
    how do I burn an AVCHD disc after FCP has rendered my h264 AVCHD and ac3 files, using Share and ‘burn to BLuRay disc’?
    Although the manual says I will be prompted to insert a disc and it will burn it, it didn’t. I’m on FCP 7.0.2 with a standard built in DVD burner.
    Thank you!
    Reinhard
    Reinhard Lorenz replied 16 years, 3 months ago 4 Members · 4 Replies
  • Michael Sacci
    June 8, 2010 at 7:05 pm
    This is a job for Compressor not FCP. If you have the files in the formats like AVCHD and ac3 you should not be in FCP.
  • Arnie Schlissel
    June 8, 2010 at 7:43 pm
    [Reinhard Lorenz] “I’m on FCP 7.0.2 with a standard built in DVD burner. “
    If you want to burn a Blu-Ray disk, you need a Blu-Ray burner. Either you would replace the DVD burner in your Mac, or you’d buy an external FW or USB burner.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Gerwyn Bowen
    June 8, 2010 at 8:44 pm
    No you can burn an avchd disc on red laser media (you are limited to 20 mins on DVD-5 approx). There’s a tutorial on kenstone.net I think that walks you through it!
  • Reinhard Lorenz
    June 9, 2010 at 5:47 pm
    Michael, Arnie, Gerwyn,
    thanks for your feedback! I went to Kenstones tutorial
    https://www.kenstone.net/fcp_homepage/burn_br_mac_superdrive_stone.html
    which was very helpful.
    Reinhard
