Activity Forums VEGAS Pro AVCHD conversion
  • AVCHD conversion
    Posted by Scott Francis on April 1, 2011 at 11:42 am
    OK, so I had someone give me some AVCHD footage and I want to “convert” it to an easier edit-able format…and it would be combined with my HDV footage. What should I convert it to? HDV, something else? I do NOT have cineform and would prefer to not purchase anything and keep it in Vegas rendering formats.
    I am looking to NOT loose any quality…it is from a Sony CX500..
    Thanks in advance!
    Scott Francis
    Mind’s Eye Audio/Video Productions
    John Rofrano replied 15 years, 5 months ago 6 Members · 6 Replies
  • John Rofrano
    April 1, 2011 at 1:21 pm
    If you don’t want to buy CineForm then I would simply convert it to HDV. This is what the VASST/New Blue FX tool AVCHD UpShift does (only automated). I doubt you will see any difference in quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    April 1, 2011 at 2:11 pm
    Yep, Convert it to HDV…And if you are using Vegas 10,
    there is no need to stress over Cineform.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Douglas Spotted eagle
    April 1, 2011 at 4:10 pm
    I don’t know if your experience will be like mine, but Vegas 10 32 loves HDV and Vegas 10 64 does not.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Stephen Mann
    April 1, 2011 at 7:15 pm
    “I don’t know if your experience will be like mine, but Vegas 10 32 loves HDV and Vegas 10 64 does not.”
    Not my experience. I have three Z1’s (HDV) and do multi-camera edits all the time. My previews and render/encodes are noticeably improved with Version 10C on my quad-core system running Win7, 64-bit.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Rob Franks
    April 2, 2011 at 3:00 pm
    Cx500 is 1920×1080. If you convert to HDV then you will cut the resolution to 1440×1080. Are you sure you want to do that?
  • John Rofrano
    April 3, 2011 at 2:03 pm
    [Rob Franks] “Cx500 is 1920×1080. If you convert to HDV then you will cut the resolution to 1440×1080. Are you sure you want to do that?”
    Good point Rob, but the question is, “can you see the difference”? 1440 at PAR 1.3333 = 1920 so it is essentially the same resolution represented with less pixels which is no worse than the compression that is being used anyway. I agree with your point, but if you can’t see a difference then does it really matter? To some people it does and if it does, those people should buy CineForm. It sounded like Scott just wanted a “good enough” solution without spending any money and converting to HDV is probably “good enough”.
    ~jr
