Activity › Forums › Adobe Premiere Pro › AVCHD bug in Premiere Pro CS4 and use of Apple ProRes
Leonardo Duarte replied 17 years, 2 months ago 9 Members · 16 Replies
Robert Battaglia
May 22, 2009 at 2:13 amSorry I don’t have an answer for you. There are some real experts on this site. You might want to re-post your question as it’s own thread.
Good luck!
Jon Barrie
May 22, 2009 at 3:09 amMate, start a new topic. There is a way to workaround your situation. It’s important you have your own topic so the solution/s are easier to find for others in the future.
-JBJon Barrie
aJBprods
http://www.jonbarrie.net -
Jeremy Donaldson
May 27, 2009 at 12:58 amDid you ever get this figured out? I’m having the same problem.
Robert Battaglia
May 27, 2009 at 11:47 pmThe only solution was mentioned above. Go to https://www.shedworx.com/voltaichd and download Voltaichd for the Mac. It works well converting AVCHD clips to AIC and possibly ProRes (go into the Prefs and set the advanced options for ProRes.) You get 10 free conversions then have to pay the $34.95. I haven’t played with it yet other than converting one AVCHD clip to AIC and that worked well.
Sorry, but that’s the best solution that I have come across. (The other option of course is to export your timeline in Premiere to a QT movie – that causes more work.)
Leonardo Duarte
July 2, 2009 at 12:01 amHello,
After you update CS4 4.1.0, Left to accept the extension m2ts
This extension is created by the camcorder Sony sr12
How do you accept again??Grateful
Leronardo -
Leonardo Duarte
July 2, 2009 at 3:58 amOlá,
Ja atualizei para o 4.1.0, mas mesmo assim não aceita o formato m2ts
Mesmo na hora de criar um novo projeto, apenas temos a opção de DV e não de HDV
No Preset não tem o AVCHDSaberia como ativar isso?
Qual seria o problema?Grato
Leonardo Duarte
