Activity Forums Apple Final Cut Pro Legacy AVCHD audio drifting in FCP7
  • AVCHD audio drifting in FCP7
    Posted by Maria-luisa Meredith on July 20, 2018 at 1:55 pm
    Hi
    I recorded an event using a Panasonic AG-AC160EJ, creating AVCHD (.MTS) files. I recorded camera audio but was also supplied with high quality .wavs from the Sound Desk.
    I used EditReady to create .movs for importing into FCP7, but when I sync the start of camera audio and sound desk audio in the timeline, it eventually drifts out of sync. Any suggestions about what’s going wrong here?
    Thanks in advance.
    M
    Macbook Pro / OSX 10.6.8 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.3
    Maria-luisa Meredith replied 8 years, 1 month ago 3 Members · 4 Replies
  • Shane Ross
    July 20, 2018 at 7:49 pm
    What is the kHz of the audio you are syncing with? 44.1? or 48? 48kHz is the better choice, 44.1 will drift.
    Shane
    Little Frog Post
  • Maria-luisa Meredith
    July 21, 2018 at 10:52 am
    Hi Shane
    Thanks for your response. I’ve double checked and both the camera audio and sound desk audio are 48khz.
    FCP Studio 7.0.3
  • Nick Meyers
    July 22, 2018 at 2:51 am
    there’s an on-going issue with audio files and sync in FCP.
    you must have your sequence pre-set set to the frame rate of your current project when you import your audio files.
    if your sequence pre-set is s et to something other than your current project, audiophile that you import can adopt the wrong frame rate and drift in sync.
    so check you sequence pre-set. make sure the frame rate matches your current work.
    (and you can’t just select the pre-set you want, you have to click in the left hand column so there is a tick or check symbol.)
    then re-import your radio and re-sync it.
    nick
    July 22, 2018 at 10:24 am
    Hi Nick
    Thanks very much for this, I haven’t used FCP in a while so your suggestion really helped me out!!
    M
    Macbook Pro / OSX 10.12.6 / 2.7GHz Intel Core i5 / 8GB 1867 MHz DDR3
    FCP Studio 7.0.3
