Activity Forums Adobe Premiere Pro AVCHD and PPro Project Manager
  • AVCHD and PPro Project Manager
    Posted by Hunter Starnes on August 8, 2011 at 5:25 pm
    Hi All,
    Using Premiere Pro CS5 on a windows 7 machine, I am backing up some projects using the project manager and I am having some problems with how it handles spanned AVCHD clips. It seems it will copy the first clip in the spanned sequence but will not copy the others. I can do this manually I guess, but is there any way to get Premiere Pro to copy these over correctly?
    I am backing up select sequences and copying media to another hard drive, excluding unused clips to reduce size.
    – Hunter
    Hunter Starnes replied 13 years, 7 months ago 2 Members · 2 Replies
  • Luis Martinez
    January 30, 2013 at 10:24 pm
    I’m having the exact same problem with the project manager in Premiere cs6.
    Did you finally solve it, or did you stick to doing it manually?
  • Hunter Starnes
    January 30, 2013 at 11:03 pm
    Doing it manually! 🙁
