Activity Forums Apple Final Cut Pro Avchd, 50i footage – project settings, transcode?
  • Avchd, 50i footage – project settings, transcode?
    Posted by Morten Slemdal on October 9, 2014 at 6:08 pm
    I have a digital camera with footage shot in avchd, 50i. When I drop it on a project in fcpx, the project is 50p. I’m going to screen it from QT on a tv, directly from my mac – mirrored – or is it a better way? Dvd? Should I change to 50i under project settings?
    Should I transcode? Uggggh – confused!
    Ronny Courtens replied 11 years, 11 months ago 2 Members · 3 Replies
  • Ronny Courtens
    October 9, 2014 at 8:38 pm
    50i = 25fps.
    If you are going to play this from QT player it is best to set your project settings to 25p.
    If you are going to make a DVD it is best to set your project settings to 25i.
    – Ronny
  • Morten Slemdal
    October 9, 2014 at 8:56 pm
    Ok, thanx.
    And transcoding is just for the workflow? If the system handles my editing, I don’t have to transcode. It doesn’t influence the Finished result?
  • Ronny Courtens
    October 9, 2014 at 10:03 pm
    If your system handles your footage natively you don’t need to optimize it to prores. This won’t affect the quality of your final master.
    – Ronny
