Activity Forums Adobe Premiere Pro AVCHD 44Mbs – Performance problems when playback backwards and “RAM abuse” with Macbook Pro
  • AVCHD 44Mbs – Performance problems when playback backwards and “RAM abuse” with Macbook Pro
    Posted by Andres Haldemyr on February 27, 2012 at 7:06 pm
    I am running Premiere Pro CS5 with a 2011 Macbook Pro, 2.3GHZ and I updated to 8GB. The Peformance is generally not bad, considering that I am editing AVCHD at 44Mbs. But:
    1) When I playback backwards (“j-key”) the image will freeze after 3 secs, same when going backwards with left arrow, frame by frame
    2) After a while editing, the computer uses (abuses) nearly all my 8GB of RAM. The image will freeze and only very unflowy playback is possible
    I tried already without success:
    – reduce the playback quality even to 1/4
    – limit the RAM distribution to 6GB for Premiere (rest for whatever)
    Anybody has ideas how to change that?
    Thanks so much
    Cheers
    Andres Haldemyr replied 14 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    February 27, 2012 at 8:20 pm
    Better get that macpro to an intervention/abuse program! 😉
    have you tried flushing the preferences and see how it goes?
    hold down option while launching premiere to do that (i think)
  • Andres Haldemyr
    February 27, 2012 at 8:55 pm
    Thank you Chris, I don’t get you, could you explain that a bit more detailed? Thank you so much
  • Chris Borjis
    February 27, 2012 at 11:53 pm
    “trashing the preferences” may fix odd issues in premiere, possibly the problem your having.
    to do it, launch premiere while holding down the shift key.
    see if that helps.
  • Andres Haldemyr
    February 28, 2012 at 4:33 am
    Thanks Chris, I tried it, the right key to hold was “option”, it trashed all my preferencies, but didn’t resolve any issues described above
  • Todd Kopriva
    February 28, 2012 at 10:12 am
    You don’t say whether you’ve installed the bug-fix updates for Premiere Pro CS5. They fix a lot of problems.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Andres Haldemyr
    February 28, 2012 at 12:23 pm
    Thanks Todd, I also have the CS 5.5 version, but for some reason the CS 5 works better for me: Like “jump to next/previous cut” (Fn+arrow up/down) is slow for me in CS 5.5, its not immediate, it takes 1,2 or even 3 seconds. Another issue is, that I have to render a normal crossdisolve, if not it wouldn’t playback it. So I went back to use CS 5, where these things work better but I still have the performance issues described above.
  • Andres Haldemyr
    February 28, 2012 at 2:04 pm
    Thanks Todd, I also have the CS 5.5 version, but for some reason the CS 5 works better for me: Like “jump to next/previous cut” (Fn+arrow up/down) is slow for me in CS 5.5, its not immediate, it takes 1,2 or even 3 seconds. Another issue is, that I have to render a normal crossdisolve, if not it wouldn’t playback. So I went back to use CS 5, where I still have the performance issues described above.
