Activity Forums Apple Final Cut Pro Legacy AVC to FCP file conversion ?
  • AVC to FCP file conversion ?
    Posted by Brett Ramsey on May 6, 2009 at 9:34 am
    Hi there,
    I am receiving files from a client using the AVC codec in an mp4 container. The files play fine in VLC on my G4 DP. look good in fact but I cannot get them into FCP at all.
    I usually use MPEG Streamclip which never lets me down, until now.
    FFMpeg also returns a not valid file message. So far the only way I’ve found to do this is play using VLC and transcode the stream. Problem is the resultant footage is very jerky and the audio is miles out of sync.
    Anybody got any suggestions as to a way to quickly transfer this footage into something that we can use?
    BTW Compressor probably isn’t the answer because it is so slow. this is News footage and if we cant do it in close to real time then we cant do it at all.
    Here’s the detail of the file from Media Info Mac:
    General / Container Stream # 1
    Total Video Streams for this File -> 1
    Total Audio Streams for this File -> 1
    Video Codecs Used -> AVC
    Audio Codecs Used -> AAC LC
    File Format -> MPEG-4
    Play Time -> 55mn 25s
    Total File Size -> 595 MiB
    Total Stream BitRate -> 1 501 Kbps
    Video Stream # 1
    Codec (Human Name) -> AVC
    Codec (FourCC) -> avc1
    Codec Profile -> High@L4.1
    Frame Width -> 640 pixels
    Frame Height -> 352 pixels
    Frame Rate -> 25.000 fps
    Total Frames -> 83141
    Display Aspect Ratio -> 16/9
    Scan Type -> Progressive
    Colorimetry -> 4:2:0
    Codec Settings (Summary) -> CABAC / 2 Ref Frames
    QF (like Gordian Knot) -> 0.249
    Codec Settings (CABAC) -> Yes
    Video Stream Length -> 55mn 25s 640ms
    Video Stream BitRate -> 1 401 Kbps
    Video Stream BitRate Mode -> VBR
    Bit Depth -> 24 bits
    Video Stream Size -> 555 MiB (93%)
    Video Encoder -> x264 – core 67 r1145M d2e1e1c
    Video Encoder (Settings) -> cabac=1 / ref=2 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1401 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Date of Original Encoding -> UTC 2009-05-02 17:59:52
    Audio Stream # 1
    Codec -> AAC
    Codec (FourCC) -> 40
    Audio Stream Length -> 55mn 25s 738ms
    Audio Stream BitRate -> 96.0 Kbps
    Audio Stream BitRate Mode -> VBR
    Number of Audio Channels -> 2
    Audio Channel’s Positions -> L R
    Sampling Rate -> 48.0 KHz
    Bit Depth -> 16 bits
    Audio Stream Size -> 38.1 MiB (6%)
    Date of Original Encoding -> UTC 2009-05-02 18:00:21
    Rob Grishow replied 17 years, 4 months ago 3 Members · 2 Replies
  • Tom Brooks
    May 6, 2009 at 12:41 pm
    What can you do? Either you use a software transcoder like Compressor or Squeeze with presets for editing formats or you find a way to play it out through a hardware card such as Kona and record the result. If it opens in Quicktime Pro, try just saving it as a QT movie. Or even try simply changing the filename extension to “.mov.” Is your Quicktime the latest version?
  • Rob Grishow
    May 6, 2009 at 5:14 pm
    I just filmed some test footage with a camera using the AVC HD codec, and you have to use Log and Transfer to import it. Make sure you choose the outside folder with all the extra folders of metadata and streams so FCP can pull it all together.
