Activity › Forums › Adobe After Effects › AVC-intra render from After Effects PC?
  • AVC-intra render from After Effects PC?
    Posted by Per Scaffidi on February 9, 2012 at 5:25 pm
    I’m doing some simple compositing and stills treatment on a PC with After Effects CS5.5 using AVC-Intra quicktime references from Media Composer. I’d like to render back to AVC-intra but I’m not seeing that option in AE. Am I missing something or is AVC-intra export only available on mac? If so, what other codec would make the most sense? Uncompressed quicktime? Thanks…
    Walter Soyka replied 14 years, 7 months ago 2 Members · 3 Replies
  • Walter Soyka
    February 9, 2012 at 7:21 pm
    DNxHD would be a good choice. You may have to download the free, cross-platform Quicktime codec from Avid.
    Walter Soyka
  • Per Scaffidi
    February 9, 2012 at 9:07 pm
    That’s actually what I’ve been using in the meantime. But I was under the impression that quicktime in any program should be able to encode AVC-intra, and our Media Composer on a PC is able to, but not AE.
  • Walter Soyka
    February 9, 2012 at 11:12 pm
    [Per Argentine] “But I was under the impression that quicktime in any program should be able to encode AVC-intra, and our Media Composer on a PC is able to, but not AE.”
    QuickTime doesn’t provide an AVC-Intra encoder.
    You can sort of render to AVC-Intra if you go through Adobe Media Encoder and choose P2 Movie. Note that it will create an entire P2 folder structure, not just a single AVC-Intra encoded MOV or MXF.
    Walter Soyka
