Activity Forums Adobe After Effects Avc-intra in After Effects
  • Avc-intra in After Effects
    Posted by Luiz Felipe marcondes on November 2, 2009 at 4:20 pm
    I am trying to purchase a camera avc-intra, But much work com After Effects and after the factory is not compatible.
    The site Adobe found an optional plug-in that reads the codec of the AVC-intra Premiere Pro, But, I do not know if the same is valid for after.
    Most of my videos would be edited in edius and I'm thinking of starting to use the systems AVID media composer and was wondering if you have any video format 4:2:2 com compression also 100MPS that I could use to make the transitions…
    Adolfo Rozenfeld replied 16 years, 10 months ago 2 Members · 1 Reply
  • Adolfo Rozenfeld
    November 3, 2009 at 2:22 am
    Dave: AVC-Intra has “intra” in the name because it doesn’t use temporal compression like the other formats you mentioned. It uses an I-Frame only flavor of H264, as far as I know.
    Adobe will release soon an (announced) CS4.2 update for Premiere Pro that will add native support for AVC-Intra files. There are no announcements about After Effects in this regard.
    Adolfo Rozenfeld · Adobe
