Activity › Forums › Apple Final Cut Pro Legacy › AVC Intra and Chroma Key Tip, maybe!
  • AVC Intra and Chroma Key Tip, maybe!
    Posted by Jeff Heck on April 22, 2011 at 1:28 pm
    Hi. I just shot footage with my Panasonic HPX-370 on a clean green screen. Typically when I use FCP I insert either a 4:1:1 or 4:2:2 color smoothing filter, then do the chroma key, and use either a green or blue color suppressor, depending on green or blue background.
    I shot using the AVC Intra codec and have discovered if you use the 4:2:2 filter with this codec, it creates several vertical lines in the finished key. If you do not use the 4:2:2 smoother, all is good. Wondering if it’s the codec that doesn’t like the filter. I used the 4:1:1 smoother, just for fun, and it’s still there.
    I guess it’s a tip for you all or a question to see if anyone else has had this issue. This is the first shoot with this camera and using the AVC Intra setting.
    Jeff Heck
    NaJor Productions
    Indianapolis
    Rafael Amador replied 15 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    April 22, 2011 at 1:41 pm
    Hi Jeff,
    Sorry but you are using the Chroma Smooth filters wrongly.
    – The 411 and 420 filters are to be applied to 411 or 420 stuff. The filter will work in a 422 or 444 sequence.
    – The 422 filter is to be applied to 422 footage and only works in a 444 sequence.
    The sequence codec needs to have more chroma samples than the footage so can retain the interpolated (smoothed) chroma.
    rafael
    http://www.nagavideo.com
  • Jeff Heck
    April 22, 2011 at 1:51 pm
    Thanks Rafael! Makes perfect sense. Don’t do a ton of chroma keying and relied on the settings of a friend.
    Jeff Heck
    NaJor Productions
    Indianapolis
  • Rafael Amador
    April 22, 2011 at 5:20 pm
    Hi Jeff,
    I haven’t used it for CK, but for years the “Nattress Chroma Smooth/Sharpening” has been my “secret weapon” when editing DV footage. Is magic.
    Drop the filter it in any DV stuff; render to any 422 codec, and -although won’t look like DigiBeta- that won’t look like DV anymore.
    Cheers,
    rafael
