Activity Forums Avid Media Composer AVC-Intra 100 and Avid Workflow : First time and need HELP!
  • AVC-Intra 100 and Avid Workflow : First time and need HELP!
    Posted by Diane Gordy on June 22, 2009 at 3:09 pm
    Hi!!
    I’m using MC 3.1.1 and editing on a MacBook Pro OSX 10.5 2.6 GHz Intel Core 2 Duo 4 GB memory.
    I have footage from an AVC-Intra 100 and not sure the best way to work with it.
    When I import the clips… I select “import p2” then get the media. But I was told I would need a separate program to read the flag frames. If this is the case… what program is that?
    I also read on other posts that it would be best to transcode the footage first. Which transcode setting is best for 720/59.94? DNxHD 145 MXF? 220? or 220x?
    Please advise the best way to go about this! THANK YOU!!
    DGordy
    Diane Gordy replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
