Activity › Forums › Apple Final Cut Pro › AVC HD and Importing Issues. From GH1
Posted by Ryan Walker on June 30, 2011 at 7:17 pmHey guys,
I have footage shot from a Lumix GH1 on my hard drive. 3 different projects, with 3 different folders with AVCHD footage.
I can navigate and open an “Archive” in FCPx to the folder that holds my AVCHD media in one of the projects, and everything imports just fine.
However, I cant use the EXACT same technique with one of the other 2 folders, to import media. I get an error explaining how this isn’t a valid file structure and what not.
How can one folder with AVCHD media be recognized, and not another one?
Maybe someone has a better workflow of how to get AVCHD media from my computer (not a card) into FCPx.
Thanks guys!
Chris Anderson replied 15 years, 2 months ago 6 Members · 9 Replies -
Adam Mccune
June 30, 2011 at 8:57 pmStrange. I went here:
https://help.apple.com/finalcutpro/cameras/en/index.html
And didn’t find any info on the GH1, which would mean it is an “unsupported camera”…which is bull, because I believe the files are the same as the GH2, and that is “supported”
Did you try importing direct from the camera. I know it seems backwards, but perhaps it is easier to ingest into FCPX?
Writer/Radio host/Community Media Advocate
Ryan Walker
June 30, 2011 at 9:03 pmHey Adam,
From the camera is no problem, and seemed to work just fine. I have a few projects on my internal hard drive, where I just dragged the mts files onto, without preserving the file structure that is created on the SDHC card once you start recording. Thing is, is that 1 project on my internal drive will import just fine into FCPx and I can start editing….but when I go over to another folder and try the same thing, I get this classic message:
(Whatever Folder Name) contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
So it seems for the future taking it off the card is fine, but for now, why do some of the files from my hard drive work, and others wont even be recognized?
Adam Mccune
July 1, 2011 at 3:40 pmThat is odd.
I know other people that have had quirky bugs worked out by making sure they are in 64 bit mode. Click on the apple logo, then “About This Mac” then “Software” then “Extension” and make sure Final Cut Pro X is marked for 64 bit applications. (should say “Yes” or No” under the 64-bit column) Not sure if this is the reason or not….but it’s worth checking out.
…another, albeit silly trick, might be to “coax” FCPx into thinking it was from the camera. Maybe try dragging and dropping the footage back onto the card and importing through the camera. Seems ridiculous, but if it clears your one-folder headache, it would be worth it.
Ryan Walker
July 1, 2011 at 3:42 pmAwesome thanks Adam. I actually have not tried either of these….will test over the weekend.
Adam Mccune
July 1, 2011 at 4:23 pmHappy I could (possibly) help.
More than likely, 64bit is on by default, but it is worth checking out. (mine was on)
Steven Capachietti
July 2, 2011 at 5:58 pmDid you ever solve importing files. I have same problem. I import and get No Importable Files when trying to import
Apple HDV 1080i60, 1440 x 1080 (1888 x 1062), Millions
16-bit Integer (Big Endian), Stereo, 48.000 kHz.It’s a quicktime file that I dragged from my Firestore FS-C digital drive and no luck. It’s a .mov file and I can import any .mov file that was not on Firestore drive. Maybe I will try to put back to drive and import. Never know. If I can’t import these files Firestore becomes useless. I already upgraded my 2007 Mac Pro 2.1 with new graphics card. I did manage to install FCP X on my 2007 Mac book Pro listed as not compatible. works but slow and understandable with 3GB of memory.
Bill O’donnell
July 3, 2011 at 2:42 amMy first thought is that your drive is not supported – FCP X wants to only use MAC formatted drives and according to my search – your drive is: “The hard drive inside the FS-4 is formatted with the FAT32 system”
I think that’s your problem
Phil Wherry
July 6, 2011 at 4:48 pmIt looks like the FireStore HDV problem is potentially a big one. Apple’s been rewriting a lot of things that used to be part of QuickTime and putting them into their new AVFoundation framework. I’m fairly sure at this point that the AVFoundation HDV codec doesn’t like the data stored in the .MOV files generated from HDV sources and saved on a FireStore drive. I’m not sure whether the problem is in Focus’ FireStore code or if it’s an Apple problem, but I can predict the outcome: Focus will blame Apple and Apple will placidly ignore the reports of trouble.
Since AVFoundation is taking a bigger role in the upcoming “Lion” release of Mac OS X, it seems probable that FireStore-generated HDV files may become unreadable to a much broader set of tools. In particular, it seems likely that FCP (not FCPX) will fail to read the files under the new OS. Those who depend on FireStore HDV files should probably wait until others have confirmed that the files are going to be usable under Mac OS 10.7.x.
Phil
Chris Anderson
July 20, 2011 at 7:55 pmFirestore files ARE NOT usable under Lion. Not only that, but Final Cut Pro 7 can’t even read them anymore. I’ve talked to both Apple and the Firstore folks about this problem, and keeping the fingers crossed for a solution soon.
