Activity › Forums › Compression Techniques › AVC 4×4 or 8×8 for Bluray
  • Daniel Low
    May 10, 2010 at 9:11 pm
    4×4 will result in smaller macroblocks, but these should only present themselves if you are using very aggressive bitrates.
    If you are authoring for BluRay you normally have the luxury of using high enough bitrates to avoid macroblocking in all but the most challenging pieces.
    Sent from my iPad Nano.
