Activity › Forums › Blackmagic Design › Available choices when capturing via composite
  • Available choices when capturing via composite
    Posted by David Eells on May 10, 2006 at 3:00 pm
    I’ve poked around the forum and can’t find an answer, so forgive me if this is a simple thing everyone should know.
    When I’m capturing via composite in, I’m not able to take in the signal as DV – I’m limited to Blackmagic DV50. What I want is Blackmagic DV, but my card (Extreme) doesn’t see it.
    Is that how it’s ‘sposed to be?
    David Eells replied 20 years, 4 months ago 2 Members · 2 Replies
  • Kristian Lam
    May 11, 2006 at 12:25 am
    Hi Budrick21,
    No, you should be able to capture to DV via composite as well. Are you capturing using Final Cut Pro or Blackmagic Deck Control?
    regards
    Kristian Lam
    Blackmagic Design
  • David Eells
    May 11, 2006 at 2:02 pm
    I’m using the BM NTSC-DV easy setup- that is, Blackmagic deck control, presumably. It shows no video input. If I use the BM NTSC-DV50 setup, then I see video.
    Is there something I should do differently?
