Activity Forums Adobe Premiere Pro A/V Synch problems after rendering with Premiere Pro 2/Fix Needed!
  • A/V Synch problems after rendering with Premiere Pro 2/Fix Needed!
    Posted by Alegator on August 28, 2006 at 2:18 am
    Hi,I captured a Hi8 NTSC tape onto my PC using the Canopus ADVC100+Premiere Pro 2.The captured file was targeted to a 2nd internal hard drive and it ended up being 24.1Gb in size. I used DV-AVI NTSC Standard 48KHz project template within Premiere. I checked the captured file from start to end and the video looks fine with no A/V synch issues. So I imported this video into Premiere and generated 16 subclips according to themes. I then exported all of these subclips into movies using same video format as captured so no reconversion would happen during rendering (DV-AVI NTSC Standard 48KHz). I checked the clips and the first 5 or 6 clips look fine but as I check later clips there’s a gradual A/V out of synch issue that gets worse in the last clip. So what happened? How come original captured file is perfect and after rendering the subclips with Premiere they turn out to have this A/V issue? How can I prevent this from happening?
    This is exactly what I did. I first imported the original captured file (24.1 Gb, no A/V issues) into the Premiere Project asset list. I dragged that file into the Source Monitor and as you say I marked several In and Out points generating the 16 subclips in the process. The way I did this is once an in and out point was marked I right clicked on the source monitor and I chose “Make Subclip…”, this generated the subclip to be listed automatically in the assets window together with the original captured file. Once all subclips (16 in total) were created in this way I exported the clips to the corresponding movie files with the same video settings as the captured file so no reconversion would happen during rendering. The way I exported the clips was by dragging each subclip into the Timeline Sequence window and then from the menu File/Export/Movie…, choosing the 2nd drive (where the orignal captured file is) as save location.This routine was done 16 times , once for each subclip.
    By “themes” I mean my criteria for setting in and out points according to the subject in the footage. I don’t think I altered any other parameter like speed, etc. I left all other options/settings in Premiere untouched.
    Alegator replied 20 years ago 2 Members · 3 Replies
  • Vincent Becquiot
    August 28, 2006 at 2:47 am
    Please specify how you are viewing the clips. This A/V sync issue may relect problems with the player and not the clip itself.
    A common A/V sync issue arises if you are viewing the clips through the Canopus box and your sound is coming from your computer speakers (The ADVC gradually gets behind as it has to convert to composite in real time.)
    These problem usually go away if you pause and start playing again though.
    Vince
    Vince Beck
    Santa Rosa, CA
  • Alegator
    August 28, 2006 at 6:17 am
    Hi, I did all of the following:
    1) The A/V synch problem is independent of the player used, I viewed the rendered movie in the monitor window within Premiere, in Windows Media Player, Nero Showtime, Cyberlink PowerDVD, etc…they all show A/V synch problem. (Audio comes out form the PC speakers using internal sound card).
    2) I rendered the same subclip with other video editing software (using the Premiere captured file as source) and there is NO A/V synch problem in the rendered file (I tried Windows Movie Maker and Ulead Video Studio 10 Plus).
    So the problem arises in the Premiere rendering process. I have no idea why Premiere is generating this problem. I’m starting to think that it might be hardware related?? I’m using a P4 3.06GhzHT, 2Gb RDRAM, 2 internal hard drives (7200rpm, 320Gb each), ATI X800XT AIW AGP, Voyetra Santa Cruz Sound Card.
  • Alegator
    August 29, 2006 at 11:13 am
    Just an update. I experimented rendering the subclip with Premiere using a different method and it worked fine, the rendered movie has NO A/V synch issues. This is how I did it: instead of generating subclips I double clicked the captured file making it appear in the source monitor. I marked the in and out points for a given clip and instead of generating a subclip I dragged directly the marked clip in the source monitor onto the timeline sequence. I then went to FILE/EXPORT MOVIE. It seems that generating subclips in the asset window slows Premiere and creates this issue in rendering.
