Activity Forums AJA Video Systems A/V Sync and IoHD
  • A/V Sync and IoHD
    Posted by Charles Caillouet on February 3, 2012 at 4:06 pm
    A couple of years ago, some of us had problems with video/audio sync in the IoHD. I studied the archived posts recently when i had a similar problem.
    My problem showed up as sliding sync between video and audio on both SD and HD captures at 29.97.
    The solution, now as back then, was to remove all conflicting drivers and components, remove the AJA software and re-load the IoHD firmware and the current AJA software.
    All seems well now, and with the announcement by AJA of support for FCX and the IoHD, i may get a few more shows out of the old box.
    Thanks to all on the Cow for sharing problems and fixes.
    cheers,
    C. R. Caillouet
    Vision Unlimited/LA
    HD Production Technical Support since 1987
    …searching for the right tool for the job…
    Charles Caillouet replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
