Activity › Forums › Apple Final Cut Pro Legacy › AV settings for a final exported @ 854×480, 48khz, 30p please any help
  • AV settings for a final exported @ 854×480, 48khz, 30p please any help
    Posted by Derekkent on May 31, 2006 at 11:18 pm
    i’ve been having some trouble getting a small test project correctly exported, but it’s small enough, and initial enough to start from scratch..
    i need to begin , however, with the correct av settings…
    i want a project with at least a resolution of 854×480 (any TRUE 16:9 res above that is fine too) , 30 fps, 48khz, and NOT anamorphic..
    i also want to export in the same res, with the same specs, and again, not anamorphic..
    my actual photographed (as aposed to rendered effects, jpgs, etc other layers) will be anamorphic (shot @ 30p on a GL2) and i hope it will correctly transfer over?
    so basically, when starting my new project, what A/v settings should I use for the right conditions in the workspace, and the correct dimensions when exporting…
    also if i need to set anything to have the anamorphic footage correctly transfer into the non-anamorphic project, what is it that i have to set..
    sorry if my thoughts are badly organized, again i’ll try to make it point form,
    new project, what av settings for
    at least 854×480, or above
    30fps, progressive
    not interlaced
    not anamorphic
    48khz
    footage will be shot in anamorphic on a GL2
    thanks so much for any help, i’m really dying of stress over this,
    Arnie Schlissel replied 20 years, 4 months ago 3 Members · 3 Replies
  • Frank Nolan
    June 1, 2006 at 12:14 am
    [DerekKent] “i want a project with at least a resolution of 854×480 (any TRUE 16:9 res above that is fine too) , 30 fps, 48khz, and NOT anamorphic”
    [DerekKent] “footage will be shot in anamorphic on a GL2”
    If you dont want the project to be anamorphic, why are you shooting anamorphic?
    I suggest you read appendix C of the FCP manual to get a better undertanding of anamorphic video.
  • Derekkent
    June 1, 2006 at 1:51 am
    i’m shooting anamorphic because it’s the only widescreen format that the GL2 shoots in, i mentioned im shooting with a GL2
  • Arnie Schlissel
    June 1, 2006 at 2:35 pm
    All widescreen formats in Standard def are anamorphic. SD in NTSC can only be either 720X480 for DV or DVD, or 720X486 for uncompressed.
    Arnie
    https://www.arniepix.com
