Activity Forums Apple Final Cut Pro Legacy av Extension
  • Posted by Steve Denn on June 26, 2006 at 11:53 pm
    FCP 4.5, G5 dual 2.5, OSX 10.3.9, 4gigs of Ram, Apple Xserve Raid 3.5T, AJA LD,
    After digitizing some footage today. I noticed in the Raid & in the folder containing the QuickTime file, there were two more files with the same name but with the extension (example) Car Chase-av & Car Chase-av-1 & Car Chase-av-2.
    Trashed Prefs & switched to the other half of the Raid.
    Still happens.
    Anyone else come across this problem?
    Kevin Monahan replied 20 years, 3 months ago 3 Members · 4 Replies
  • Kevin Monahan
    June 27, 2006 at 4:32 am
    Steve,
    Was this on a Capture Now? Is the RAID properly initialized for the Mac OS?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Jerry Hofmann
    June 27, 2006 at 12:43 pm
    Might need to turn off the file limiting size in the Scratch disk settings. If it’s set to limit file size, longer captures will create these files.
    Jerry
  • Steve Denn
    June 27, 2006 at 4:47 pm
    Yes to both. This just started yesterday. This system has been up & running fine for the last year with no problem. ok problems did start yeaterday.
  • Kevin Monahan
    June 27, 2006 at 10:07 pm
    If you initialized with Mac OS extended, then your scratch disk prefs are probably doing this by limiting file sizes to 2 GB. As Jerry says, from now on work with that pref box unchecked.
    BTW, it’s far better to log and capture rather than capture now. My opinion, anyway.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
