Activity › Forums › Avid Media Composer › auxiliary timecode…easy way to do it
  • auxiliary timecode…easy way to do it
    Posted by Giselle Murillo on January 19, 2010 at 2:02 am
    hey i’m playing with media composer and it’s been a while since i’ve played with it…
    so i lined up the shots with the music track and i spaced on setting the auxiliary timecode on it…. there are no breaks in any of the tracks, and it’s footage from 3 tapes…..and i can’t remember an easy way to do it….just need to set it and then group it….
    so what number am i looking for to punch in the column in the bin
    any help would be swell
    Giselle Murillo replied 16 years, 8 months ago 2 Members · 2 Replies
  • Paul Harrington
    January 19, 2010 at 11:27 pm
    If you mean Multicam for a line cut without matching code, place a in point on each cam roll. In the bin menu select Group Clips sync using in points. Then you can cut via multicam…Hope this is what you meant…
  • Giselle Murillo
    January 28, 2010 at 1:33 pm
    thanks…i got it after. i was trying to figure out what to punch in and shortly realized i needed the punch in the first frame timecode of the subclip…so pretty much what was on the slate. it all came back to me…
    thanks for your help though
