Activity › Forums › Apple Final Cut Pro Legacy › Aux TC bug when Timecode Rates differ
  • Aux TC bug when Timecode Rates differ
    Posted by Steven Gonzales on June 5, 2007 at 2:46 pm
    I have a video source at 23.98 frames per second (ProRes422) with 24 fps timecode.
    I also have separate sound files, with 29.97 timecode.
    I would like to place the audio timecode in aux timecode field of the video.
    So in Modify Timecode, I have Source TC at rate of 24.
    I check Aux TC 1 and set rate to 30 and type in a 30 timecode (such as 01:01:01:29).
    As soon as I enter, the timecode in Aux TC 1 converts to 24 fps timecode (00:59:29:02).
    I submitted bug report to Apple. So right now you can’t autosync via Aux TC when the timecode timebases are different.
    Rafael Amador replied 19 years, 3 months ago 3 Members · 3 Replies
  • Kevin Monahan
    June 5, 2007 at 6:21 pm
    What if you do the Modify > Timecode to the Sound TC prior to merging the clips?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Steven Gonzales
    June 5, 2007 at 7:20 pm
    I have a smart slate which displays sound timecode (this is shot on film), so I want to place the sound timecode in the Aux TC field of the video clip.
    I’m not sure what I would modify on the sound timecode, since that is what matches the smart slate.
  • Rafael Amador
    June 6, 2007 at 12:36 pm
    Hi Steve,
    I don’t know if this can helps, but I think that with the QT Player you can change a TC track for the oder one. Have a look in “Properties” (Com-J).
    Cheers,
    rafael
