Activity › Forums › Boris FX Particle Illusion › AutoUpdate Error Message
  • Alan Lorence
    July 16, 2012 at 1:58 pm
    I think you need to login as administrator, or r-click on the particleIllusion shortcut and “run as administrator”, then try the update.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Tony Mcdermott
    July 16, 2012 at 7:56 pm
    I’ve re-installed Particle Illusion, restarted my PC and ran Particle Illusion as Administrator, however, I still get the same error message, I can’t think what it could be.
  • Alan Lorence
    July 16, 2012 at 8:20 pm
    Were you logged in as admin, or did you use “run as admin…”? Try both if you haven’t.
    If that still doesn’t work, just download the emitters from the wondertouch website and unzip them manually.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
  • Tony Mcdermott
    July 16, 2012 at 9:12 pm
    Will do, how do I Login as Administrator?
