Activity › Forums › Avid Media Composer › Autosync not working properly
  • Autosync not working properly
    Posted by Vicky Peters on September 15, 2016 at 12:29 pm
    Hi everyone,
    I’m trying to autosync this subsequence to turn it into a synched subclip but for some reason the Avid leaves off my audio tracks when I autosync two particular subsequences. I’ve checked – the audio tracks are selected when I autosync, there are no extra bits of video lying around etc. It worked fine with a few other subsequences I have pulled from the same long sync sequence as the problem clips. Any insight?
    Thanks so much x
    Michael Phillips replied 10 years ago 2 Members · 1 Reply
  • Michael Phillips
    September 15, 2016 at 1:23 pm
    Are there any adapters on that particular subsequence? All events on each track are of the same duration (should be if sub-sequencing)? Audio tracks are of the same sample rate?
    Michael
