Activity › Forums › Adobe After Effects › Autoscroll suddenly stops
  • Autoscroll suddenly stops
    Posted by Frank Meyer on July 26, 2017 at 2:17 pm
    Hi everybody,
    I have a strange problem, hopefully you can help me.
    Imported an image and gave it an autoscroll effect. It works fine, however, it suddenly stops after a few minutes, the same for other objects, although delayed. I set no keyframes or other stuff, the only thing I can imagine it has something to do with the clip (I made it longer twice, and think the problem might occur at the point where the former end-point of the composition was)
    Any ideas how to solve this?
    Thank You !!
    Joe Sciberras replied 2 years, 8 months ago 3 Members · 3 Replies
  • Frank Meyer
    July 26, 2017 at 3:17 pm
    it doesn´t stop when previewing
  • Michael Szalapski
    July 26, 2017 at 6:54 pm
    So you’re saying when you preview your composition, everything is fine, but when you render it, it stops moving? That’s odd.
    It’s probably to do with how far the layer has moved in comp space. There is a limit.
    Is this a credit scroll or something else?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Joe Sciberras
    January 26, 2024 at 8:41 pm
    i was having this problem too. i was able to get it to render correctly. i split the layer right before it stopped. (edit>split layer) I also had to split a few more times after some test renders.
    good luck
