Activity Forums Adobe After Effects Expressions Autoscale Text Box with fixed height ?
  • Autoscale Text Box with fixed height ?
    Posted by Jelle Bonn on December 11, 2019 at 10:08 am
    I managed to make a dynamic box with the code below where when you change the text and it automatically resizes to fit the box.
    The problem however is that when I have letters like ‘y’, ‘p’, ‘q’, ‘Q’, the box height becomes larger and I dont want this. I want to have a fixed heeight because I have an animation with a white line next to my box and their height should be the same.
    How can I resolve this? Thanks.
    SIZE
    s=thisComp.layer("1 - Name LastName");
    w=s.sourceRectAtTime().width;
    h=s.sourceRectAtTime().height;
    [w,h]
    POSITION
    w=s.sourceRectAtTime().width/2;
    h=s.sourceRectAtTime().height/2;
    l=s.sourceRectAtTime().left;
    t=s.sourceRectAtTime().top;
    [w+l,h+t]
    Andrei Popa replied 6 years, 8 months ago 3 Members · 4 Replies
  • Andrei Popa
    December 11, 2019 at 2:19 pm
    Would modifying the white box accordingly bee a problem? So when you have Q’s, the white box would also be higher?
    Andrei
    My Envato portfolio.
  • Patrick Middelkoop
    Hi Jelle!
    You can in fact fix this very simple.
    In the Size-expression you can change the `h` to `value[1]`
    So it would look something like this:
    SIZE
    [w, value[1]]
    POSITION
    [w+l,h+t]
    This will now fix the standard height to the value you set it in After Effects itself.
  • Jelle Bonn
    December 11, 2019 at 4:38 pm
    I’m making this lower third (template) to use on different video’s, and I need them to be on the exact same position in every video. So I can’t change the height of my white line. I am searching a way to give my blue box a fixed height even when I use letters like ‘Q’ that takes more space.
  • Andrei Popa
    December 11, 2019 at 5:11 pm
    If it’s only the horizontal size that you want modified, you can use this expression for size and set the vertical size to one that fits your text manually.
    //SIZE
    [w,value[1]]
    Andrei
