Activity Forums Apple Final Cut Pro Legacy autosave versions need reconnecting / re-rendering
  • autosave versions need reconnecting / re-rendering
    Posted by John Mcmullin on March 22, 2010 at 5:50 pm
    Hi all,
    I’ve been having a problem in that periodically FCP crashes. When we open the last version from the autosave vault it needs reconnecting, even though the location of the media hasn’t changed. After reconnecting the whole sequence needs re-rendering. It’s an HD project of 70 minutes long and this is a bit of a killer.
    Any ideas why this might be happening? Obviously we’re trying to do a manual save as often as possible now.
    Thanks in advance.
    John
    Arnie Schlissel replied 16 years, 6 months ago 3 Members · 4 Replies
  • David Roth weiss
    March 22, 2010 at 5:59 pm
    John,
    Let me get this straight. You’re asking us for advice on how to fix a broken backup system that’s designed to safeguard your broken main system, and you’re not even trying to fix the main system?
    Sorry, but I understand that forging ahead with creativity may seem like a good thing, but it’s not. You need to stop moving forward with your edit and find the root cause of the main issue that got you into this situation, otherwise you’re just digging a deeper hole.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • John Mcmullin
    March 22, 2010 at 6:17 pm
    Well thanks,
    I guess you’re referring to the FCP crash as the broken main system.
    It seems to crash when under RAM pressure. It’s a large sequence in HD. Not doing it all the time, just 3 or four times a day, which I would say is more or less par for the course in FCP with a heavy project in HD. But maybe not.
    I was hoping someone would have seen the autosave problem before. We’re actually delivering the programme tomorrow. Be good to know for the future in any case. If we remember to save often it’s not so bad.
    John
  • David Roth weiss
    March 22, 2010 at 6:30 pm
    Try moving just the main sequence(s) to a brand new project and see what happens.
    With regard to the relinking issues, that typically relates to bad logging practices such as illegal characters, files named untitled, bad reel numbers and/or no reel numbers.
    David Roth Weiss
    Los Angeles
  • Arnie Schlissel
    March 23, 2010 at 1:15 am
    [John McMullin] “Not doing it all the time, just 3 or four times a day”
    I would hate to know what you mean by “all the time.” For me 3 or 4 times a month is all the time, and unacceptable. I regularly deal with HD and even 2k for film. If your system is stable, it will not crash.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
