Activity › Forums › Apple Final Cut Pro Legacy › autosave
autosave
Posted by Jerry Wise on August 19, 2010 at 7:43 pmAre there keystrokes to “force” an Autosave?
John Paterson replied 14 years, 7 months ago 6 Members · 6 Replies -
Jason Diebler
August 19, 2010 at 8:28 pmShift+Command+S, Return 🙂 “save as” – what’s the difference?
“The deepest blues are black” – Foo Fighters
(this doesn’t help me when I’m chroma keying!) -
Michael Sacci
August 19, 2010 at 8:47 pm[jerry wise] “force” an Autosave”
By definition Autosave just happens if you are forcing it it is not “AUTO” but you can do a save or save as. But there is no versioning in FCP that gives you auto-naming so you have to name each save as.
Ron Pestes
August 19, 2010 at 9:30 pmJust set up your autosave in preferances for a short time period. I use 4 minutes but thats just me. Some use 15 minutes or so but I would hate to have to do even that much editing over again. I save 25 copies of autosave and then they just get deleted automaticly after that.
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro -
Jeremy Garchow
August 19, 2010 at 10:35 pmI hit command option s extremely frequently.
Save early. Save often.
John Paterson
January 5, 2012 at 6:41 ama normal save or save as does not write to the autosave vault which is the whole point of an autosave. You want to have a version that you can ‘roll-back’ to in the event of a disaster.
John Paterson
January 5, 2012 at 9:05 amFurther investigation has shown that it is indeed possible to force FCP to do an autosave to the Autosave Vault. To do this open the User Preferences by pressing Alt+Q. Go to Autosave Vault>Save A Copy Every and enter a time of Zero minutes. This will force FCP to do an Autosave immediately, and it will also reset the Autosave time to the minimum of 1 minute. You should then reset the Autosave time to something more usable like 10 minutes before carrying on.
