Activity › Forums › Apple Final Cut Pro Legacy › autosave
autosave
Posted by Randolph Harrison on January 10, 2007 at 7:36 amI noticed in my autosave folder, the older saves looked like the FCP icon, but then the rest of them were white/blank icons. Is it saving or is there an issue?
Thanks guys,
RandyRandolph Harrison replied 19 years, 8 months ago 3 Members · 3 Replies -
Rafael Amador
January 10, 2007 at 11:16 amTry to open them. If they open properly should be a problem of the Finder that display the thumbsnails wrong. Relaunch the Finder: Apple Menu> Force Quit>Finder>Relaunch. If the FC thumbnails keep wrong, fix the Finder with Techtools or Diskwarrior.
salud,
Rafael -
Bouncing Account needs new email address
January 10, 2007 at 1:11 pmWhen my Mac does this I just “Repair Disk Permissions” with Disc Utility (Mac) and everything comes back.
If it persists,
you can also
Re-boot from your “OS X Installer CD” (hold down the “c” key while starting the Mac with the CD in the drive)
When the CD window first opens after the restart, select “Disk Utility” from the pull-down Menu.
Then run “Repair Disk” on the System Disk
and all should be well agian.
