Activity Forums Apple Final Cut Pro Legacy automating stills exports
  • automating stills exports
    Posted by Hagaik on January 1, 2006 at 2:10 pm
    In my workflow, i’m required to export about 10-15 still frames from each project.
    I do this, of course, through the file>export>using QT conversion…
    I assigned a keyboard shortcut for this command, but what bugs me is that every time i invoke the export using QT conversion, the chosen format (quicktime movie/AIFF/still image etc.) is reverted to “quicktime movie”. is there any way I can default the format to still image instead?
    Thanks in advance, and a happy new year to all
    Chris Miller replied 20 years, 7 months ago 3 Members · 2 Replies
  • Nick Meyers
    January 1, 2006 at 10:43 pm
    collect all your stills in one bin,
    then use batch export.
    read this:
    https://www.lafcpug.org/tutorials/basic_batch_export.html
    when i’ve done his i actually make freeze frames from the clips first.
    this has 2 advantages:
    one is that there’s no chance of the frame “drifting” from the chosen one like there is if the clip is “live”
    two is that i can re-name the freeze to represent that particular frame/image.
    you cant do that with a master clip without all instances of it changing, too.
    then i batch export the whole bin with whatever settings i want.
    cheers,
    nick
  • Chris Miller
    February 25, 2006 at 10:55 pm
    thank you that has saved so much time!!!!!!
