Activity › Forums › Adobe After Effects › automating multi sequence loading
Posted by Dror Lazar on May 5, 2005 at 10:11 amHi
IDror Lazar replied 21 years, 4 months ago 3 Members · 6 Replies -
Barend Onneweer
May 5, 2005 at 11:22 amI actually place each image sequence in its own folder… Keeps it nice and tidy and it helps with these kinds of situations.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Filip Vandueren
May 5, 2005 at 3:23 pmAs a dirty work-around:
select the first item, tick on “force alphabetical order” as well “tiff sequence”
You’ll get one long footage and can cut that up into pieces.Not a pretty soluition and not advisable if there are different aspect-ratios, field-orders, framesizes etc.
But it might do the trick. -
Filip Vandueren
May 5, 2005 at 5:20 pmHi,
I’ve hopefullty solved your problem.
my first attempt at a jsx file.
This is an adaptation of the smartImport script. The original script just assumed that once it found 10 numbered files in a folder, the entire folder contained 1 still-sequence.
My script compares the basenames (everything at the start of the filename, before the numbers) and works out how many different sequences there are.get it here:
Dror Lazar
May 8, 2005 at 8:00 amit works gr8!!
thanks Filip, thank you very much :o)
can I be rude and ask for a simple modification?
i’ve noticed that it imports the footage with no alpha, I’ve tracked down the function in the scripting that allows to declare alpha modes, but i didn’t knew how or where to plug it (me dont know scripting very good, me be not so smart…)
can you add a function in the script that interprete the alpha as a “premultiplied”?again, thank you very much, you already made my life a lot easier…. 🙂
Dror
Filip Vandueren
May 8, 2005 at 7:26 pmHi Dror,
I’ve updated the script (had to work around a bug, but I found a great script by jdnorthup from the adobe userforums)
Note that I set the script to Guess for the Alpha Type, I think that will be the most helpfull, AE usually gets it right, if you don’t start the sequence with an entirely 0 or 100% alpha frame.
+ you can easily transfer interpretation settings from 1 to multiple footage items using the “remember interpretation” and “apply interpretation” commands.
download from the same url:
enjoy,
Filip
Dror Lazar
May 9, 2005 at 7:12 amThanks Filip
it’s working great, it really made the whole importing stage a 1-2 seconds instead of monkey file selecting procedure. 🙂and the tip about interpretation copy/paste is really helpfull, so thanks again.
and in conclusion
(thanks)*2 :o)Dror
