Activity Forums Apple Final Cut Pro Legacy automating export of many QT ref files of sections from a timeline?
  • automating export of many QT ref files of sections from a timeline?
    Posted by Shayne Weyker on March 12, 2007 at 4:39 pm
    I would like to be able to take a FCP 5.1 timeline with lots of 1 minute interviews on it, each separated by still graphic bumpers and make a web-format file for each.
    I’m guessing part of the answer involves exporting a bunch of QT ref files and giving those to compressor as a batch.
    Can anyone tell me (or point to the place to find out) how I might best automate
    1) setting of in and out at the right places (just before and after the bump for each interview) and
    2) exporting that section as a ref QT using a sequential file name?
    Please let me know too if it matters if each interview (between the bumps) is a single clip or if it has cuts in it.
    Shayne Weyker
    https://weykervideo.com
    Matt Larson replied 19 years, 6 months ago 4 Members · 6 Replies
  • Shayne Weyker
    March 12, 2007 at 6:14 pm
    Re: setting the in and out, I was thinking there might be a applescript/automator-able way to make the CTI jump to the start of the next clip in the timeline that matches a certain property (the title of the bumper graphic).
    If I could do that then there could a macro/script that would do something like
    begin loop
    set in point
    move CTI to start of next bump
    move CTI to next cut
    set out point
    export QT ref with filename = loop’s count # to a set folder
    repeat until loop count = number of interviews
    which should work if the CTI started at the start of the bump for the first interview.
    –Shayne
  • 13 Create COW Profile Image
    13
    March 12, 2007 at 6:19 pm
    by the time you get scripting to do it properly (if you can at all) then you most likely could have just exported each one individually and batched processed them in compressor
  • Big D editor
    March 12, 2007 at 7:16 pm
    You can also batch export by selecting the sequences in a bin and right clicking, selecting batch export. It completely bypasses Compressor and does everything in FCP.
  • Matt Larson
    March 12, 2007 at 9:56 pm
    The best I can come up with is to manually set an in and an out where you want it for each clip and then make it a subclip. FCP will automatically name your sublips sequentially (Sequence 1 Subclip 2, Sequence 1 Subclip 3, etc.) Once you have your subclips, highlight them all and export with compressor, or if you’d rather, choose “Batch Export”
  • Shayne Weyker
    March 13, 2007 at 1:53 am
    Getting closer.
    Re: the one sequence per interview: Is there a simple way to take one in-to-out from the master sequence timeline and make that a new sequence? Can that in-to-out include cuts or must it be a continuous single clip?
    I can put the bumpers in each short sequences I guess.
    Re: one subclip per interview approach: the interviews would be captured from multiple tapes, would that cause the auto-numbering to reset? Is there a workaround? I’m not concerned about being able to recapture later so using one reel # for all the tapes would be okay if FCP would let me.
    –Shayne Weyker
  • Matt Larson
    March 13, 2007 at 2:53 pm
    [Shayne Weyker] “Re: one subclip per interview approach: the interviews would be captured from multiple tapes, would that cause the auto-numbering to reset? Is there a workaround? I’m not concerned about being able to recapture later so using one reel # for all the tapes would be okay if FCP would let me.”
    Auto naming is based on the sequence name, so that has nothing to do with reel#.
